Buzzing from engine.
My chain tensioner is bad the head is buzzing need to replace. Any suggestions on a aftermarket one, or should i just do oem replacement? I thought i had seen a ksport chain tensioner about a year ago but cant seem to find it anywhere maybe it was another brand not sure but i was pretty sure it was ksport. Any info would be appreciated.
There has been many discussions on the best method to take when your TCT goes bad. Billman can provide you a modified one that will not fail. Or you can try to work on your own by sand blasting the worm gear. Sand blasting has had mixed results but Billman won't do ya wrong
MM3Kwolik
06-20-2024 03:39 PM
Facian
07-20-2018 09:02 AM
RumRunnerS2k
08-26-2016 11:42 PM
