Buying a new MAP sensor for a AP1
I have 2002 AP1 and the engine has the notorious rough idle that occurs during stop and go traffic or when shifting from R to 1st gear and back, etc. I know its because the ECU is "learning" but it annoys the hell out of me. I tried doing the MAP sensor "whack" and fiddling with the connector but it hasnt gone away.
I read some where that there is a newer MAP sensor which eliminates the issues. Is this true? and would it be the same MAP sensor which comes on all newer MY s2000's ?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Originally Posted by trivium,May 20 2007, 08:22 PM
cleaning the IAC? How DO I do that?
it's just a metal part bolt onto the driverside of the motor, you can take it out in less than 15 minture, a can of throttle body/intake manifold cleaner(5-6buck) and an old toothbrush will do it.
make sure you don't kill the rubber gasket by dipping it into the throtte body cleaner.
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
I thought I was having the MAP sensor problem. Bought a new one. Same problem. The throttle body and injectors were clogged, causing the problem.
Had the local lube place do the 15 min cleaning (~$60) and haven't had a problem since.
Originally Posted by CKit,May 20 2007, 08:33 PM
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
the throttle body cleaner i used was by valvoline synpower, same brand for injector cleaner.
and for motor, i used the OEM honda top engine cleaner
