Burnt vs. Bent valve
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
What is the difference between a burnt valve and a bent one (if there is one). I know honda is quick to point the abuse finger at a bent valve, but can a burnt valve even be caused by driver error?
how is a burnt valve caused? and is it always on exhaust valves?
thanks!
thanks!
This is probably not the answer you're looking for but based on the way you asked your question .....................
A "burnt" valve results from a chemical/thermodynamic event - usually from a bad valve adjustment and poor valve seating.
A "bent" valve results from a mechanical contact event - usually from a valve hitting a piston.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Valves can also burn from :
being bent in the 1st place, a bent valve won't seal againsdt the seat. It will burn where the margin of the valve isn't in contact.
Inccorrect assembly
recessed valve seats
wrong valve retainers used that contact the rocker arm
Inccorrect assembly
Local lemon law investigator was telling me that they have seen a small number of cars (7?) that have valve guides that are about .0005 too small. At high RPM that allows the valve to float ever so slightly and make contact with the piston. Honda dealers want to pass it off as driver error (missed shift, etc.) but the ECU keeps a record of highest RPM. You can pull that information with the PGM scan tool. They have seen this problem with 7000 rpm or less as max rpm.
Please keep in mind that this is a very limited problem but one that you might want to investigate further. If your car is still under warranty in California, PM me and I will get your contact information to him.
A 00 to 03 car will only record RPM at the time a DTC occured, not highest RPM turned. The 04 and newer car will record max RPM if they where mechanically overreved.
Considering how many drivers have botched a shift, bent valves in a S2000 is usually driver error.
would a car idle and drive fine if there are possibly 2 bent or burnt valves? my car is below leak down %'s in cylinder 1 and 4, but the car idles fine and drives fine. the dealership hasn't given me a for sure answer, but after the leakdown test, the threw those out as possiblities.
any other ideas? if it wasn't for the check engine light, i would not have known that the car needed service...
