Burnning lots of oil and dont know why.
Old 06-15-2011, 07:47 PM
Former Sponsor
Moddiction's Avatar
If you check when cold the oil level will be lower than normal so can over fill that way.
Old 06-15-2011, 07:52 PM
s2cho's Avatar
thanks for the tip!!
Old 06-15-2011, 11:36 PM
MeganFoxAP1's Avatar
Mobil 1 tends to burn quickly.
I switched over to AMSOIL 5w-40 and got a lot less of burning oil
A quart maybe ever 1k miles.
Old 06-15-2011, 11:45 PM
s2cho's Avatar
Just ordered some 10w-30 ATM. Heard it doesnt burn that much. Hopefully it will work and it'll me a Amsoil Fan haha.
Old 06-16-2011, 01:58 AM
mmm...vtec's Avatar
i noticed u didnt say anything about smoking. does it smoke at all during driving? during start up after its been sitting a while? also im assuming u only did a dry comp test and not a wet one...do a wet comp test as compare the results to the dry one...also how many miles?
Old 06-16-2011, 02:44 AM
vasquezgno's Avatar
iv'e been burning oil too like 2 quarts every 1k miles and cant seem to find out why. I did a compression test and all 4 cylinders came out 215 but i didnt do a leak down test. i will keep an eye on this thread to see if u find out whats wrong.
Old 06-16-2011, 03:09 AM
mmm...vtec's Avatar
everyone does a comp test first...but if u do a leak down test first its kinda like killing 2 birds with 1 stone...do a leak down test FIRST and go from there....
Old 06-16-2011, 07:03 AM
JohnsS2000's Avatar
i drive mine hard and burn about a half quart between changes, every 3000 miles without fail. I use Castrol GTX(non synthetic) that is alot more than i have hearf of others burning. Any smoke at all ?? That would be an indicator, if you have smoke what color?
Old 06-16-2011, 10:47 AM
s2cho's Avatar
70k miles now and no smoke at start up or when driving. Unless im shifting at 9k then there will be a poof of black smoke.
Old 06-16-2011, 10:50 AM
s2cho's Avatar
and btw is castrol gtx good? I heard good things about non synthetic with out v-tec motors.
Quick Reply: Burnning lots of oil and dont know why.
