burning too much engine oil
#24
[/quote]
Glad mine is abnormal. I run either Mobil 1 or Pennzoil Synthetic 10w-30. I change oil between 6K and 8K miles. Rarely add more than 1/2 quart between changes. Car has been heavily autocrossed since new.
#26
if you're burning alot of oil just run regular oil, not synthetic. synthetic oil is very thin, and burns faster. run regular 10w30, it won't hurt the motor and will burn alot less. i used to run it in my high compression integra type r when it started to burn synthetic alot.
#27
put whatever you want in there. They are both good, run it see if it burns less if not then swap to something else. Every motor is different so there is no correct answer.
Hobb
07-29-2002 06:17 PM
