Burning smell in the cabin/under the hood?
Old 04-13-2009, 12:28 AM
JUSTINTHECOASTIE's Avatar
Question, was your res ever full before? I understand that you have coolant in the radiator. Check to see where coolant in the res goes. If your level dip then you have a (slow) leak somewhere and it's possible. Dont rule anything out if you want to fix the problem mate
Old 04-13-2009, 04:39 AM
Joshualeet's Avatar
The weather has been pretty shitty here lately, but I got to check the car out yesterday. It would appear as if my vtec solenoid is leaking oil. I'm just going to replace the gasket and hopefully that will fix it. I don't see any other problems or leaks anywhere else.
Oh, and I was pretty convinced it was a plastic bag, but I checked, and alas, no bag
Old 04-13-2009, 07:32 AM
street_ruler's Avatar
if it only happens after a few minutes of driving it might be your cat...those make an odd smell
Old 04-13-2009, 08:16 AM
fatjoe10's Avatar
Most likely not your case, but I'll throw this out there. I had a burning smell going on for a few days. I had enough of it, and on closer inspection I found out that one of the wires coming out of the underhood fuse box was loose. The Phillips screw that held it down had backed off, and the false contact made the terminal overheat and started melting the plastic cover. I tightened it down and the problem was solved. Good luck to you .
NFR-S2k-
05-28-2016 04:29 AM
skem
09-10-2009 07:01 PM
Gienek
05-10-2009 07:51 PM
phoQ
11-17-2008 08:50 PM
dmd92east
04-25-2003 06:06 PM
Quick Reply: Burning smell in the cabin/under the hood?
