Burning Oil
Burning Oil
I have been burning a small amount of oil. Maybe an "X" mark every1- 2 weeks. I do drive fairly agressive. I didnt burn a drop until I put my TP on, what do you guys think.
How many miles on your '04?
How aggressively do you drive?
What oil are you using now?
Are you sure you're not losing any from a slow leak ... like a loose oil filter?
Originally Posted by Emil St-Hilaire,Aug 15 2010, 07:35 PM
Nothing to do with the test pipe...
the TP won't cause changes in oil consumption. You should try to quantify the consumption in terms of quarts per 1000 miles to figure out if it is worth worrying about.
Any other chnages made to the vehicle in recent times, change in weather conditions, did you change the type of oil ?
Im using mobil 1 10w-30. Its never burned a drop unitl the tp. There was no damage in putting it on. I do expect to burn some oil, I'll just keep an eye on it
Originally Posted by Emil St-Hilaire,Aug 15 2010, 04:18 PM
The more you Vtec,the more you'll burn oil...
mrkim019
11-28-2005 10:02 AM
