Burning Lots of Oil
Burning Lots of Oil
Hey guys I have a 02 and i recently had the motor bebuilt because i mis-shifted. It was done by a very reputable shop. Anyways it has about 7000 miles since the rebuilt and seems to be burning lots of oil. The last oil change was about 1500 miles ago and it burnt around 2 and 1/4 quarts. Is this normal or should i take it back to the shop. What could cause this and i see no oil leaks.
thanks Jason
thanks Jason
How extensive was the rebuild? Did the shop hone the cylinders? New rings? This might be contributing to the oil consumption, especially if you've been VTECing the engine.
Personally, I think that 2.25 quarts in the first 5500 miles isn't excessive on a newly rebuilt engine. That's not excessive even on a fully broken in engine.
The rebuild included new pistons (Arias), sleeves, valves, valve guides, retainers, etc. etc. So far i put about 6-7k miles since the rebuilt. The last time i changed the oil was about 1500 miles ago with castrol gtx 10w30 and oem filter. I checked the oil yesterday and it took a little more than 2 quarts to fill it back up. I hit vtec a couple times a day and drive a little agressively.
Thanks for all the help!
Jason
Jason
What is the compression ratio? Do you have a turbo/supercharger on it? If so, was it on during break-in? How did you break-in the motor? What oil did you use to break-in the motor?
gregor_konstantin
11-27-2012 05:04 PM
