Buring Smell
Buring Smell
I have this really bad burning smell coming from my driverside rear wheel and not sure what it is..
I broke it down to two possibilities.
Brakes? maybe they are bad?
I got my tires changed today and noticed that same wheel, the springs are sitting kind of off. I did change the springs to eibach.. maybe that is the problem?
have any of you had experience with this? thanks for th help
I agree with the other posts that the burning plastic smell is usually from plastic getting caught underneath the car, stuck to the Y-connection leading to the dual exhaust outlets; but if you've checked underneath the car; I suggest that you jack the car up, pull the wheel of and check for any visible sign of the culprit.
