Building the block
Building the block
i was wondering can you make the bore bigger and stroke longer in the s2000 block? How far can you take it?
Im thinking about turbocharging my s2000 as soon as i get it.
I've got a spare block and im about to slevee it and put in new rods/pistons with about 9.8:1 compression and a T3/T4 turbo setup from full race.
Check this one, it's just at the very limits bore wise with 89mm. Any larger than 89mm in the stroke and you go over square and must compromise.
https://www.s2ki.com/forums/index.php?showtopic=222111
User #: 20654
S2KI Age: 1 yrs 189 days
PPD Average: 1
Owner
2000 Berlina Black /Black
SLC
US
I let Joe Alaniz go wild with the objective of building a streetable all-motor competition setup for my S2K. Here's an overview of the work that Joe did:
- Big Bore to 89mm. With the 88.5 crank, this brings displacement up to 2202cc.
- 88.5mm crank (AN ALANIZ EXCLUSIVE)
- Replace with high strength ductile iron sleeves.
- Custom pistons made by ARIAS to Alaniz specs including soft-edge radius done by Joe (kept stock CR)
- Rings (low tension type)
- Rods (Cunningham Ultra light rods made to Alaniz specs)
- Custom bearings Tri-Metal race type (AN ALANIZ EXCLUSIVE)
- New oil pump
- Competition Head Work
- New bronze valve guides
- Titanium retainers
- Oversize black nitride valves on intake and exhaust
- Clean, Flow, and Calibrate injectors (RC Engineering)
- Balance engine
- Blueprint block to ALANIZ race specifications
I'll post additional details including bench flow data, dyno, etc once available.
PPD Average: 1
Owner
SLC
US
- New oil pump
- Balance engine
