Broken Door Handle
Broken Door Handle
So a couple of weeks ago I closed the door on my s2k and the door handle came completely off of the panel, I had my boyfriend take it a part and he said that the small green clip (or whatever it is ) is broken so that the handle won't stay intact no more. I tried to glue it back in but it only worked for a little while. I was wondering if this has happened to anyone, or if any of you guys have any suggestions on what I should.
--Here are some pictures. I think possibly it's the greenish yellow piece that needs to be replaced but I'm not sure..
http://www.hondaautomotiveparts.com/auto/j...gry5=DOOR+LOCKS
Can you find the part number? If so, just order it at the local dealership. Any parts in a box are sold as a set, fyi. Parts 22 and 38 are the outer door assemblies, for example. $57 to replace the whole thing unless you get one at a junk yard for less.
Also, what part exactly fell off?
http://www.hondaautomotiveparts.com/auto/j...ONT+DOOR+LINING
This may not be good advice for you.... but normally stuff breaks on doors when they are being slammed shut... so if that is something u do I would suggest being gentle : ) so this doesnt happen again.
