broke a wheel stud
Old 12-14-2011, 10:38 PM
  #51
nartnailuj's Avatar
OK I'll get them. But I went to less Schwab and thru didn't carry any centering rings for the bbs Lm. I believe I may have to order them from bbs. I'm going to try to find a way to get my hands on some.
Old 12-15-2011, 05:50 AM
  #52
Billman250's Avatar
Received 1,401 Likes on 839 Posts
YOU DONT NEED RINGS!
Rings are for wheel bores that are too big. Yours are too small. Just bore the wheel to the size of the hub.
It wouldnt make sense to bore it too big, then get rings to fill it back in...get it?
Old 12-15-2011, 05:55 AM
  #53
DFWs2k's Avatar
Rings aren't specific to a wheel, they are based on the hub size/bore of wheel and car.
The only reason I said bore to 73 and get rings is so that you won't have problems selling these in the future.
Sent using free Tapatalk - Android FTW
Old 12-15-2011, 12:49 PM
  #54
nartnailuj's Avatar
Ohhh okay I understand. So I don't need rings bc I am boring out the wheels so it fits over my hub. and rings are for bores that are too big. But isn't 73 larger than or stock front and rear bore?
Old 12-15-2011, 01:06 PM
  #55
spets's Avatar
It was a typo on my part. Bore them either to 70 front 63 rear OR You can just do 70 on all 4 and you don't need to bother with rings for the two wheels on the rear. That would also let you rotate the wheels if you run a square tire setup.
Old 12-15-2011, 02:47 PM
  #56
nartnailuj's Avatar
So if I bore them all out to 70, I still wouldn't need rings even if the rear is 63 on the hub of the car? 70 will bee fine over the 63 without the rings.
Old 12-15-2011, 04:59 PM
  #57
CKit's Avatar
Correct, but you have to be VERY careful about tightening them down bit by bit in a star pattern. Do it while partially jacked so the weight of the car isn't resting on the rims / studs or else you'll gall the studs and / or destroy the lug nuts.
Old 12-15-2011, 11:55 PM
  #58
nartnailuj's Avatar
Ok I will. thanks everyone.
RUNVTEC
06-13-2013 11:03 PM
DFWs2k
07-15-2011 06:40 PM
p0staboy
03-25-2010 07:02 PM
SebRedAP1
09-01-2009 06:56 AM
RHAP1CD2
02-27-2007 10:35 AM
Quick Reply: broke a wheel stud
