broke a wheel stud
Old 12-12-2011, 08:18 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Front bearing and hub has to be disassembled and pressed to do the studs.
Buy a torque wrench before you total your car and yourself...
Old 12-12-2011, 08:34 PM
Bugsy's Avatar
I always torque them too... Guns in the wrong hands are just too damaging without torque sticks.
Just for fun, old vid below. Still can't figure out how all 4 wheels hit the ejector seat simultaniously...
http://youtu.be/jv4m41viy4I
Old 12-12-2011, 09:45 PM
nartnailuj's Avatar
So its not safe to drive from sacramento to sf to my friends shop on 3 studs? roughly 90 miles. and i will invest in a torque wrench, but how much does it cost?
Old 12-13-2011, 12:49 AM
ahrmike's Avatar
Get a cheapy from Walmart (20-30 bucks) or a Beam torque from Sears. Putting your "weight into it" - not a good idea. You probably weight at the minimum 150-160. The lug wrench itself is a little more than a foot long. Assuming you're not using a breaker bar OR jerking it with your weight, you're putting 160 ft-lbs of torque - already 2X more than what is spec'd (80 ft-lbs).
Old 12-13-2011, 01:06 AM
ZDan's Avatar
If you were on three KNOWN good studs, I'd say go ahead. But you're on 3 (probably 18 if you've torqued them all the same number of times) studs that are most likely ALSO compromised and on the verge of breaking. I woudn't drive it. The possibility of a wheel departing the vehicle is very very REAL.
Torque lug nuts to 80 lb-ft. More is not "better"!
Old 12-13-2011, 02:10 AM
SgtB's Avatar
Use a torque wrench. They can be had cheap.
Old 12-13-2011, 04:48 AM
Billman250's Avatar
I strongly agree on this. you can indeed have the wheel break off the car. I've had a guy break 5 studs on the way to my house due to overtorquing. He lost a rear wheel and destroyed the quarter panel.
Old 12-13-2011, 05:20 AM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
Short studs ? Are you running spacers on that wheel ?, if so that would explain the shorter studs. Short studs will break on you depending on the size of the spacers, and improper torque makes it even worse. 80 ft lbs is the spec, that isn't very tight. Torque wrench is worth it's weight in gold.
Old 12-13-2011, 07:50 AM
DFWs2k's Avatar
Dude, those wheels don't fit.
If you are breaking studs, something is wrong. Does the wheel even fit up against the hub?
What car are the wheels you are tryin to put on off of?
DON'T DRIVE IT WITH THE NON OEM WHEELS AND 3 BROKEN STUDS, since you don't even know for sure if they fit.
Old 12-13-2011, 09:20 AM
rrounds's Avatar
DON'T DRIVE IT AT OVER 25 MPH TO A SHOP CLOSE TO YOU. Sacramento must have about 200 shops that can fix your studs.
Get it fixed.
ROD
Quick Reply: broke a wheel stud
