Bringing My AP1 Back to Life
Old 05-23-2020, 04:13 PM
hand banana's Avatar
@Billman250
Old 05-23-2020, 06:44 PM
rpmgem's Avatar
Originally Posted by hand banana
PM’d Billman for a rebuild list
Old 05-24-2020, 04:44 AM
Billman250's Avatar
Received 1,397 Likes on 837 Posts
Did you completely rule out the intake and exhaust valves as source of the compression loss?
Old 05-24-2020, 10:37 AM
rpmgem's Avatar
Are there for for sure signs that tell it’s the intake/exhaust valves? My mechanic basically just assumed it’s the rings. I could hear the air escaping during the leakdown but was hard to tell exactly where it was leaking from
Old 05-25-2020, 07:11 PM
Slowcrash_101's Avatar
You can tell if it's the rings by putting a small amount of oil in the cylinder and doing a compression test. If rings are bad, if you put a bit of oil(like a tsp) in the cylinder it will bump compression. No change then it's either valves or head gasket.
Honestly though I doubt it's rings, since it's only one cylinder, the chances of bent or burnt valves is high.
Old 05-25-2020, 08:10 PM
rpmgem's Avatar
Appreciate the compression tip I’ll redo the compression test adding a bit of oil to cylinder 2 and see if anything changes. What gets me thinking is the head has around 30k on the rebuild and no mis-shifts that would cause a bent valve. Will report back with the updated compression results, thank you to everyone chiming in
Old 05-26-2020, 03:33 AM
Billman250's Avatar
Compressing test is useless, only a leakdown test, following the audio signal of the leak, will determine valve condition.
Old 05-26-2020, 09:29 AM
rpg51's Avatar
I have little doubt that the first thing he will say is that you don't decide the treatment until you have the diagnosis. Also, if ends up being a bottom end problem, think long and hard about embarking on a rebuild project with this engine. These pages are filled with failed bottom end rebuilds. Its a tough engine to rebuild. Lots of good money thrown after bad. That's my take anyway.
Old 05-26-2020, 03:31 PM
rpmgem's Avatar
UPDATE**
So I redid Compression today:
cylinder 1-160
cylinder 2-80
cylinder 3-155
cylinder 4- 170
I added a small amount of oil in each cylinder for a wet test and each cylinder bumped up about 10psi. When we did the leakdown, I heard air escaping not sure exactly where. My mechanic was already saying it’s rings but with the wet test what do you guys believe? Bad valves?
Old 05-27-2020, 02:01 AM
rpg51's Avatar
The diagnostic data you are missing is the location of the air leak during the leak down. I wouldn't make any decisions without that information.
rpmgem (05-27-2020)
Quick Reply: Bringing My AP1 Back to Life
