Brief grinding noise after start up?
When I start my car after it has been sitting for a day or two, it starts, then there's a brief grinding noise for a second or so (immediately after start, not while cranking). It usually doesn't happen if I start it later that day. What could be the possible causes of the issue?
Thanks?
I can link a video if needed.
Thanks?
Starter issues.
1 Post
Starter doesn't pull back fast enough. Mine does it from time to time. I believe Billman and several others have looked into it without any success in a permanent fix. Haven't had any issues yet with mine, and flywheel and starter teeth looked ok both times I changed out clutch.
The bendix pin doesn't retract fully so you get grinding occurring, I think that was more common on ap2's ?.
Common to all s2ks.
Mine has been doing this for quite a while, and is now showing signs that it has had it (the bendix is starting to retract during cranking making a new not-happy noise)
I've been putting it off until you solved it once and for all!!
