Break in the 2.5L inlinepro engine
Old 05-27-2005, 02:11 AM
  #111
honda9krpm's Avatar
an aem cold air intake may give a little bit more gain Juan
Old 05-27-2005, 03:05 AM
  #112
S2000_Europe's Avatar
Danh
The problem is inside the engine, we made two run on with the cat and other without the cat and the result were almost the same, these means that the engine can not get more air, we use a brand new K&N filter. inside the engine can not flow more air.
Juan
Old 05-30-2005, 02:50 AM
  #113
Honda are tead don the engine
They have opened the carter and did not found any metal pieces
They Have taken out the valve cover and everthing is in place
Compresion test is perfect
Oil was very dark ( less than 1000 km with them) Which can be the cause?
this afternoon they are going to take the head off
Old 05-30-2005, 03:18 AM
  #114
honda9krpm's Avatar
good luck
Old 05-31-2005, 12:15 AM
  #115
Well bad news...
Honda opened the engine, and found that the cylinder #1 and #4 have the sleeves with lot of scrathes and the piston where loose!!!! They told me that this could be for two reasons:
First; over rev, which is imposible because my rev limit is 7.500, 500 rpm below than Jeremy told me
Second; lack of lubrication
inlinepro is not anwsering my emials so I do not what to do.
Juan
Old 05-31-2005, 07:30 AM
  #116
Chazmo's Avatar
Juan, sorry to hear the bad news. I've been following your thread. No advice to offer, just condolences. I'm guessing that too much heat (lean burn or, yes, bad lubrication) would be the culprit. Sigh.
Old 05-31-2005, 09:02 AM
  #117
I sent the block to a second shop and they told me the same, bad lubrication
inline pro installed a new oil pump what can be cause? I played safer than theytold me I use an AEM MES instead a VAFC 7500 rpm instead 8000 rpm I have such bad luck with this car Thinking in taking all out and sell it
Old 05-31-2005, 10:42 AM
  #118
VeilsideAP1's Avatar
Juan, there were some other motors owned privately that failed as well. I'm not going to bash inline pro and start throwing out names and circumstances, but I think you should resolve the issue with them first and foremost... This is why I mentioned in another post that I didn't think it would be a good idea for you, especially living in Spain... Just so you know yours isn't the only one...
Old 05-31-2005, 11:01 AM
  #119
beroznikmal's Avatar
It really sucks when you are one of the few out there with no one to offer any help... I feel ur frustration. Good luck and if you need help pleas pm me buddy.
Beroz
Old 05-31-2005, 02:54 PM
  #120
Since they do not anwser my email i will call them tomorrow. Honda and other shop told me that is becasue a lack of lubrication.
james When I read you post was to late....
Beroz thanks for your help if i need some part will let you know.
I am going to put new sleeves and check if pistons are ok. what I do not know is if the iron of the sleeves are a spceial iron or same iron that is used on others cars.
Juan
Quick Reply: Break in the 2.5L inlinepro engine
