Brakes S-2000 = RSX are they the same ?
Last night we started the measuring process for fitting a big brake kit to the Acura RSX . The RSX does use the same caliper as the S-2000 and it also uses the same brake pads . The front rotor is the same diameter and width but has a different offset . The rear rotor is smaller in diameter and it is also thinner . We are producing the engineering drawings to determine the changes required to install kit .
Just some observations from what we measured . Honda reduced rear rotor diameter to reduce rear braking effort . Because of this reduction they could reduce thickness of rear rotor . The raised steering arm placement allowed them to move caliper and rotor inward . Because the pads are the same on both cars we should see a reduction in pad costs , in the next few years . ( higher production numbers)
The brake lines are totally different , we will also be working on a braided line set fitment .
I know that there was a lot of speculation on what parts were interchangeable , this is the reason for this post .
brad
brad
Originally Posted by MaskedAP1,Dec 10 2006, 07:31 PM
any more info about RSXs brake = S2000?
Originally Posted by type-j,Dec 10 2006, 10:04 PM
they stopped production on the rsx?
I think it wasn't "upscale" enough for Acura's brand image.
SakeBomb Garage
61
11-24-2023 05:17 PM
s2000ellier
Member S2000 Classifieds and For Sale
03-17-2019 11:34 AM
SakeBomb Garage
01-02-2017 10:52 PM
