brakes locking up while driving.
I need some help big time.. i have my front brake calipers that will lock up during driving leaving the engine to fight the front brakes its the passenger side front that does it the most. the drivers just hints at doing it. i have bleed the system umpty million times what the heck is going on. brake pad on the passenger side is smoking to make matters worse im 777 miles from home.. the more i drive the more they tighter they get due to the brakes expanding i need some help fast...
Stuck caliper. The slidey pins get stuck and the piston just keeps pressing on the rotor or the piston gets stuck out.
They need to come apart and you need to re-grease (with brake grease) the slidy pins to start. You might want to slap some new pads on there while you're at it.
If you don't work on the car, you need to find some place to fix the brakes.
Either the slide pins are seized, the caliper pistons aren't retracting, a brake hosae is coming apart on the inside acting as a check valve, or you've got petroleum contaminated brake fluid.
hmm
well i swapped the brakelines around hoping the problems would move to the other wheel.. and i dont have any failures with the brakelines swapped now im moving to SS brakelines. im thinking since the lines are bent in the opposite direction now the problem is gone.
