Brake warning light on after break job...
Hey guys,
I had the front pads and rotors done on my 01 S2000 today. They also drained and replaced the fluid. Now the brake warning light in the dash is on and won't go out. Any suggestions as to what might cause this?
-s
-s
Originally Posted by RedY2KS2k,Jun 17 2009, 07:22 PM
You paid someone else to do the work. Take it back to them. Diagnosis is their problem, not yours.
Obviously if the fluid really is low, then the shop needs to fix the problem.
If the fluid was low I would just fix it myself rather than risking brake failure on the way to the shop. Just check the fluid level to make sure it is up, if so the float is stuck. Good luck!
Thanks for the replies. This is a case of a sticking float. The master cyl is full but even after I pull the float back up to the top it eventually sinks. I'm thinking I should just unplug the sense and call it a day at this point.
-s
-s
-s
