Brake Rotor Screws
Brake Rotor Screws
Trying to get my rotors off and found out the rotor srews were stripped. I purchased an easy out kit, but my drill is a off the shelf POS and will take me hours to drill to use the easy out bit.
Question:
Is there an easier way to remove the screw or is there a way to bypass the screws altogether to remove the rotor?
-Joshua
Question:
-Joshua
An impact screwdriver may still work depending on the stripped-ness of the screws. Soak 'em in PB Blaster and tap them out. Otherwise, you are going to have to drill.
Originally Posted by MitsukillinS2K,Jul 13 2008, 02:59 PM
Do the screws have to be in there or are they over rated
If you want 100% security leave them on. They certainly make it next to impossible to remove the rotor while they are in.
Take them out and go to a track day with a any of the lugs not property tightened an kiss your ass goodbye.
