Brake Rotor Replacement
I will switching out my rotors in the next few days. I have looked at the service manual and it looks pretty straightforward. Look like 80 ft-lb caliper bolts will be the hardest aspect of the swap.
Any pitfalls I should be aware of?
Pretty easy. If you're mechanically competent, you don't need the manual for anything but torque specs.
2nd on the impact driver. Worth it's weight in gold. Those rotor screws can be fused on there pretty well, but an impact breaks them free in <2 seconds.
I've used those before, but now I have a cordless impact driver/drill. It's good for ~100lb-ft, according to the specs. Wasn't sure if it would be up to the task, but it worked great for removing my rotors recently.
