Brake Pedal Pulsing
Old 12-15-2018, 10:13 AM
dannyhsu's Avatar
Default Brake Pedal Pulsing
My brake pedal developed a pulsating feel today. It appears to only happen when stopped at red lights. When I'm braking just to slow down and not to stop, I don't believe the pulsating feel is there. Any ideas what the problem could be?
Old 12-15-2018, 02:04 PM
Car Analogy's Avatar
Received 1,439 Likes on 1,071 Posts
You need to clarify, because what you wrote implies you feel pulsing while the car is stopped and you are sitting at a red light. Clearly that isn't what you meant. But its unclear what you did mean...
Old 12-15-2018, 03:47 PM
dannyhsu's Avatar
Sorry about the confusion, but that's actually what I mean't. I only feel pulsating from the brake pedal stopped and sitting at a red light.
Old 12-15-2018, 04:14 PM
zeroptzero's Avatar
Received 3,767 Likes on 2,658 Posts
sounds like your pedal is dropping when stopped, it can't really pulsate so I am assuming it is dropping under foot, check for any fluid leaks around the vehicle.
Old 12-15-2018, 04:46 PM
dannyhsu's Avatar
Dropping? Like the pedal is hitting the floor?
Old 12-15-2018, 05:11 PM
windhund116's Avatar
Received 1,533 Likes on 1,037 Posts
How many miles on the disc and rotors? Could have warped rotor.
Old 12-15-2018, 05:51 PM
He feels the pulsing when vehicle is stopped. Sitting. Parked.
Either his car is possessed, or its not really pulsing that he is feeling...
Old 12-15-2018, 08:34 PM
zeroptzero's Avatar
moving towards the floor in small increments. The only real pulsating that happens in the brake system is from the ABS motor, but you would hear it activating and I can't see it happening in a stopped position as it is designed to activate at speed.. This is definitely a first either way.
Old 12-16-2018, 05:52 AM
Deckoz's Avatar
The check valve to your brake booster has likely gone bad
remove the hose and check the valve is functional.
Old 12-16-2018, 07:05 AM
dannyhsu's Avatar
Hmm maybe pulsing is the wrong word? I feel some sort of tapping every other second that seems to be coming from behind the brake pedal when stopped.
Quick Reply: Brake Pedal Pulsing
