Brake pedal problem after full brake change
It only does this at low(40 and below)speed. Basically it feels as if the brake pedal is moving in and out and pulsing. The car isnt doing it, only the pedal. Passengers cant feel it.
Here is everything I did when I did the brake job.
Bought stoptech stainless lines, cheap rotor blanks and stoptech street pads. painted the calipers(g2paint) off the car because I put new lines in. After the job the car didnt feel right so I bled the lines again and again using different methods. No air coming out it seems. All good. Checked for leaks. All good. The brakes might be getting a tad better as I use them but I don't think its right. I followed everything from a book. So im stuck. Any advice please.
Double check over everything, something isnt right. Ive never heard of an issue like this. Seems like a MC problem or the booster as vacuum would be different in low rpms vs steady highway driving.
Did you hear about the MC recall on 2006's? What year is yours?
its highly doubtful that brand new rotors are warped out of the box, even if they are cheap...and if it was warped rotors, the only way your buddy could feel it is if he drove it and the pedal pulsates when the brakes are applied...hes not going to feel it in the passenger seat
He said he felt it pulsate and vibrate. I was thinking it wasn't a problem with rotors either. I might have some install pics I can post. I was painting so I took some pics here and there.
