Brake pad replacement
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
brakes are obviously important for safety. I would have someone do it with u the first time. Its not something u should try out on your own even with step by step directions.
I bought the factory pads and paid the brake/suspension/aligment shop I always use $150 to do the job. He had to turn the rotors three times since the previous owner had race pads on the car and tracked it quite a bit.
Don't bother replacing your pads if you aren't replacing the rotors or at least getting them turned.
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
DIY!!!!
Buy the pads..
Either buy the tools or borrow them.
Put your car on jackstands and take the rotors to a shop to have them all turned if they need it.
It is NOT a difficult job.
You can DO it!
Buy the pads..
You can DO it!
I dont know how you feel about doing this. But if you walk around the bay doors of a dealership, and see a mechanic working on a car. Ask him if he wants to do a brake job at his garage at home. Odds are he will gladly want the cash under the table... and WONT be chargeing $65+ an hour.
Also avoids waiting for an appointment!!
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
Changing the pads is easier than an oil change, and that is really easy. Get a pad spreader and a bleed kit and for a couple of hours you can do it the first time. Get a knucklehead friend to show you if you want. I would get some antisieze for the screw, but that is about it.
chrisjgiuliano
02-21-2008 10:04 PM
