Brake light stays on...
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
So i recently picked up a s2000. When i test drove it i noticed the brake light was on when i was driving. I thought maybe it was just low on brake fluid (it really was). when i got home i put it brake fluid and the brake light was still on... Does the light have anything to do with the brake pads? any ideas to fixing this? i checked also the E-Brake and everything seemed fine there. Here's some pics to help out... thanks for looking.
![Name: BF5BCAAB-8ED5-49B1-B608-3082C2E3EB00-10723-000007FC697A8C9F_zpsb7bec60b.jpg
Size: 77.1 KB](https://www.s2ki.com/forums/attachments/s2000-under-hood-22/134123d1501791993-brake-light-stays-bf5bcaab-8ed5-49b1-b608-3082c2e3eb00-10723-000007fc697a8c9f_zpsb7bec60b.jpg)
E-Brake up...
![Name: A536F035-00E6-4A72-AB5D-56D78A33EFCB-10723-000007FC75B298B5_zps3cd38a15.jpg
Size: 62.1 KB](https://www.s2ki.com/forums/attachments/s2000-under-hood-22/134124d1501791993-brake-light-stays-a536f035-00e6-4a72-ab5d-56d78a33efcb-10723-000007fc75b298b5_zps3cd38a15.jpg)
E-Brake down...
![Name: 4DD07937-446D-4904-8492-161B2E544520-10723-000007FC7AB1F7B3_zps99cc93c8.jpg
Size: 64.4 KB](https://www.s2ki.com/forums/attachments/s2000-under-hood-22/134125d1501791993-brake-light-stays-4dd07937-446d-4904-8492-161b2e544520-10723-000007fc7ab1f7b3_zps99cc93c8.jpg)
i know my brake fluid is dirty... doing a flush soon.
![Name: AEFE455D-9477-4FCC-A8C6-BAF63622D4AA-10723-000007FC84E34175_zps18856352.jpg
Size: 87.8 KB](https://www.s2ki.com/forums/attachments/s2000-under-hood-22/134126d1501791993-brake-light-stays-aefe455d-9477-4fcc-a8c6-baf63622d4aa-10723-000007fc84e34175_zps18856352.jpg)
E-Brake up...
E-Brake down...
![Name: D808DCAF-2D42-41FE-974F-D1E7AE57EABA-10723-000007FC7FA2B8D9_zpsb7340d34.jpg
Size: 67.5 KB](https://www.s2ki.com/forums/attachments/s2000-under-hood-22/134127d1501791993-brake-light-stays-d808dcaf-2d42-41fe-974f-d1e7ae57eaba-10723-000007fc7fa2b8d9_zpsb7340d34.jpg)
Wait, if you are justing unpluging and pluging the electric connector, then it doesn't work. You have to use something to poke on the white floater INSIDE the the reservoir to make sure it floats up instead of sticking at the bottom. It's sticking to the bottom because the fluids where low and dirty causing it to not float back up when you added more fluids.
