Brake Light Indicator
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Ok so its been like 10 degrees in PA for a few days and now when I get in my car and drop the e-brake the brake light indicator stays illuminated. I did some research on the site and found some people have had the float get stuck meaning the brake light stays on, but I used a flat head screw driver and pushed it up and the light stays on. I am changing my brake fluid today but if this leaves no change in the problem I was wondering if the e-brake could simply freeze stuck, I'm not getting any grinding sound but there are only two things that I can tie this problem too. Either a low level of brake fluid or the e-brake being applied.
Just looking for some feedback!!!
![ponder2.gif](https://www.s2ki.com/forums/images/smilies/ponder2.gif)
I get it too. THe brake light either stay on or is intermittent when it is very cold. I tryied lowering the top and it wouldnt go down until i pulled up the brake so its not that. But sometimes when I brake it goes away. It doesnt come on when its warm and the brake isnt on. I think its just what others have mentioned.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
only 2 options....
if its not the brake fluid or the float...
lift up your center console and see if the switch under the ebrake is "frozen" and not going down all the way.
![](http://img.photobucket.com/albums/v467/BuyAMS/631.jpg)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
The same thing happens to everyone's s2k when it gets cold. It happened to me as well, like you mentioned it's just the float getting stuck. There is a TSB for it somewhere on this site with a cheap part you can get from Honda to fix it, but I can't remember where it is. So, long story short it is fixable if you don't mind buying a new part or you can just ignore it like I do lol.
