Brake light on *HELP HELP HELP*
I wiggled the brake fluid container plug and nothing. The fluid is clean and up to MAX. I will however unplug the e-brake switch later when i get home. I'll let you know later.
Hey, I had the same problem... tried everything. Finally took it to honda, they said the float in the master cylinder was stuck...
Had them flush the brake system... light went OFF!!
Good luck!
Good luck!
