Brake Grease
Old 07-16-2001, 01:47 PM
Tanqueray's Avatar
Default Brake Grease
A couple of us took a driving class last week. Afterwards, we had some intermittant squealing. When we examined the brakes, we saw that the brake grease (or anti-squeal goo in Mcco's case) between the pads and shims was totally cooked...it flaked off when you removed the shims.
We used the small packets of stuff sold at Autozone -- can anyone recommend something which can handle time on the track without being destroyed? Are there high performance/temperature brake grease products?
Thanks!
Old 07-16-2001, 01:56 PM
cdelena's Avatar
I use 'high-temp' caliper grease that still gets cooked every track event. I just redo the shims when they get too noisy for me.
Old 07-16-2001, 02:01 PM
jschmidt's Avatar
I've had good success with the spray can CRC stuff.
Old 07-16-2001, 07:54 PM
Mikey's Avatar
I use NAPA anti seize lubricant. It's a metallic looking paste good up to 1600 deg F.
I also use it on the caliper bolts and lug nuts. I haven't managed to cook it yet.
It's a NAPA brand product and costs about $10 for an 8 oz bottle.
Old 07-17-2001, 03:40 AM
cdelena's Avatar
[QUOTE]Originally posted by Mikey
[B]I use NAPA anti seize lubricant.
Old 08-23-2001, 06:58 AM
johev's Avatar
will a Super Trak have the Napa anti seize or do I need a napa store???
Sounds like the best bet...
Old 08-23-2001, 07:06 AM
Mikey's Avatar
You would probably have to get it at a Napa store. However other brands of high temperature anti seize lubricant would probably work just as well.
Old 08-23-2001, 11:40 AM
johev's Avatar
thanks mikey....
Old 08-24-2001, 03:36 AM
cdelena's Avatar
Old 08-27-2001, 07:45 AM
Mikey's Avatar
I just got back from a track weekend and really gave the NAPA compound a tryout. My brake pyrometer showed temps of all 4 wheels at 550 deg F+, and that was after a cool-down lap. I can only imagine they were a few hundred more at some hard braking points.
Anyway, the anti-seize compound is still evident and not burned up on the backing of pads. But the Porterfield R4S's were starting to look very white.
Quick Reply: Brake Grease
