Brake calipers removal!
Hello guys,
Im gonna remove all four brake calipers for a repaint, it seems to be easy, but once the caliper is removed, all the brake oil will spill out from the brake line and i have heard that you cant let air/water/moisture gets into the brake/ABS system,
I know that one of the function of brake oil is to prevent it from happening,
Could you guys tell me the best way to remove the calipers without the fear
to let the air/water/moisture gets into the system? possible to get something the wrap brake lines?
Thanks very much for help!!
I got a set of these:
http://www.amazon.com/OTC-Tools-OTC4506-Fu...p/dp/B002YKHRUK
and put them on the brake lines. Kept the fluid from leaking out.
trackrabbit21
08-11-2015 11:14 AM
