Boot strip brake light problem
Hi has anyone had a problem with the strip brake light on the boot not working. I have tested the unit seperately and it is fine, I have checked the connectors at the rear and there is NO power getting to the connector. Any ideas, its driving me crazy. Thanks Dave
check continuity to chassis ground on both wires - especially power. if it has continuity, its shorting to ground somewhere - probably pinched. if its not, follow the wires til you see where its cut. If its not, check fuses?
M005
09-01-2008 10:50 AM
