Body Shop Fixed My Car
Old 10-03-2007, 12:42 PM
SheDrivesIt's Avatar
How many miles are on the new tires? They will be pretty squirmy for a couple hundred miles until the mold release is worn away. It's not just on the surface of the rubber but penetrates a little.
Old 10-03-2007, 04:41 PM
negcamber's Avatar
Originally Posted by LubedKoala,Oct 2 2007, 11:37 PM
They replaced the rears with the correct tire size.
It doesn't matter if they replaced with the correct tire size...the WHEEL size can effect the contact patch. If the wheels are fronts they will be narrow and pull the tire in to the bead reducing contact patch.
But Billman's comment is probably right on...needs an alignment.
Old 10-04-2007, 01:00 AM
s2gZ's Avatar
make sure that the sidewall/speed rating are the same on your fronts and backs. my bimmer had z rated in the front and h rated in the back and i felt like all hell was about to break loose every time i got on the freeway.
just a thought...
Old 10-04-2007, 10:10 AM
jyeung528's Avatar
z & h?
wow.
Old 10-04-2007, 05:16 PM
LubedKoala's Avatar
It's not the tires guys. All my tires are properly inflated and have the correct sizes. My tires do need to break in though, but I know these tires and how they act brand new. There's definitely something else going on. I'm taking the car back early next week for them to see what's going on. I'll keep ya'll updated. lol, care to see my itemized receipt?
Old 10-08-2007, 04:55 PM
LubedKoala's Avatar
Is it possible to find something to counter the loss of frame rigidity in the rear?
I'm pretty sure the slight frame damage and new quarter panels is what is causing my car to do this.
some sort of reinforcement like x-brace, anti-sway bar, etc?
Old 10-17-2007, 06:13 PM
LubedKoala's Avatar
Got the car back from the shop. Part of the problem was that one of the rear rims had a bent hub and so had to be replaced. Alignment was good. The car handles a little better, but at higher speeds (70+) the rear end does have little too much play in it.
Given my circumstance, would it be better to go with a rear lower tie bar, rear strut or rear X-brace? You know, to help counter the frame/quarter panel damage. I know these will at least help my situation by increasing the frame's rigidity, but I didn't know if there was one I should go with first.
*I'm not expecting a full restoration of the car's handling, just want something to help it.
Old 10-22-2007, 10:11 PM
BruceWarne's Avatar
Hi, before you spend money, try this:
Take your rear wheel off.
Loosen all the the upper and lower control arm bolts (at the bushings that connect to the frame). Make sure you don't turn the eccentrics that set the alignment (or mark them so you can turn them back to where they were).
Put a jack under the lower control arm, and jack it up until the top control arm is about parallel to the ground.
Now tighten the control arm bolts.
This should take some of the pre-loading out of the bushings (they were supposed to do this when they installed them). That pre-loading made my car handle like crap (the rear felt like it was floating on a waterbed). And it took me months to track down. Might not be your problem, but it's worth a try.
Also: Make sure your shocks are still ok.
Did they fit new coilovers? If they fitted used one, make sure they're from the same model year.
Old 10-24-2007, 12:43 PM
LubedKoala's Avatar
I don't think I have what it takes to do this, but sounds like something that should definitely be checked. They reused my old coilovers.
rob-2
09-26-2012 12:25 PM
markc24
08-03-2007 05:02 AM
sjt
10-27-2006 09:38 AM
blckndvoodoo
03-16-2006 02:46 PM
MagicDave
12-04-2003 09:43 PM
Quick Reply: Body Shop Fixed My Car
