Body roll...eliminating/reducing
#41
[QUOTE]Originally posted by gernby
My point was the 225/50's in the front REDUCE grip due to rollover (for street tires), and 225/50's in the rear REDUCE grip due to reduced width.
#42
Well, I posted this in another thread because I couldn't find this one. I guess I didn't look hard enough.
Here's my question(s):
I've done some reading. Very interesting stuff. I'm sure I haven't got my head around all of it, but enough so to make a start.
I'm thinking springs and roll bars are a start toward what I want. My last S was lowered 2" and had comptech non-adjustable sway bars F and R, and I can remember a distinct difference in handling. I didn't think about it much until now though because those changes were made by the previous owner, so that was the only way I ever knew the car.
I have two questions: If I liked how that car handled, can I assume that I need to go F and R sway bars? I've heard mixed thoughts on this issue. Some say go both, some say go front only. Also, I have no intention of dropping 2" again. No more than 1" this time for drivability around town.
Number two: Assuming I'd like to go with F and R sway bars, but I'd also like to dial the oversteer down just a bit. I'm leaning toward the Saner bar for it's bang for the buck. Someone has also mentioned that Saner makes a rear bar. I'm wondering if I can match F and R Saner bars but dial the F one notch stiffer than the R. Does that sound like a decent plan?
Here's the other thread I posted in:
http://forums.s2ki.com/forums/showthread.p...threadid=162981
#44
Originally posted by munckee
Anyone?
Anyone?
Sway bars are just one component of the suspension and there are different recommendations for different year models and different uses. Here is a bit on sway bars for background:
http://www.teamscr.com/sway.htm . You may want to read it over, and maybe comeback with more specifics for a discussion of mods that fit your need.
#47
munkee, your proposed setup would indeed reduce oversteer. (More tire on the front should be part of the equation too) The Saner front and rear setup is a good one now that they make an adjustable rear bar as well. It gives you a variety of setup choices. I don't have experience with the Comptech bars, so I can't help you there.
I wasn't knocking the rear bar in my earlier post; I just don't think it's necessary for most applications on our car. ('03 and earlier, the MY '04 has a looser rear and might be a different story.)
#48
[QUOTE]Originally posted by drewchie
#49
The '04 has more tire on the rear, but they put a thinner sway bar to make the ride softer. As a result, it's not quite as punishing going over the bumps, but also not as tight as the earlier ones.
srovner
09-25-2018 04:13 AM
