Blown head gasket
Old 03-24-2018, 01:34 PM
MarcusDubya77's Avatar
Default Blown head gasket
So, my head gasket blew. I am pretty sure it was caused by heat. I was still doing datalogging for the start tune and had noticed several instances of 200 plus temperatures on the AEM software. I assumed it was the calibration. I am now to the point of either stroking the motor or swapping to an LS or K24. This sucks and I leave the country in 75 days, so I am on a schedule to get this thing up to be shipped. Pics for consoling my heart...
Old 03-24-2018, 01:52 PM
noodels's Avatar
Would be easier to replace head gasket.
do you think you may have had an air lock that may have caused the over heating issue ?<there is a bleed valve on the oem manifold>
Old 03-24-2018, 02:28 PM
I wish I knew. I have no idea. I had to put in the second AEM EMS after the first was fried. I don't know if it's a sensor issue or what. The radiator fans do kick in. I just had a lot of sporadic temp spikes. It really does suck.
Old 03-24-2018, 03:49 PM
flanders's Avatar
How did you bleed it?
Old 03-24-2018, 03:56 PM
What do you mean? I didnt bleed anything, so I can guarantee it has something to do with it. I probably messed up. This is becoming a nightmare.
Old 03-24-2018, 04:30 PM
noodels's Avatar
Fans would kick in as steam is hotter than coolant
replace HG and jack front of car up Very high to and remove air from cooling system.<bleed valve is there for a reason>
Old 03-24-2018, 04:37 PM
noodels's Avatar
pps we all fcuk up now and again,cost me an engine, so your lucky its just a HG
Old 03-24-2018, 04:53 PM
Thanks. I hear you, but man I just want this done. Especially given that I am pressed for time. I am thinking of having it stroked to 2.4 while it's at the shop or just do a K24 with turbo swap. Maybe I can recoup a little money by selling the parts.
Old 03-25-2018, 03:14 AM
flanders's Avatar
When you changed manifold to the ITB's you lost a lot of coolant.
Did you just refill the radiator and not bleed out all the air pockets?
Old 03-25-2018, 03:50 AM
That is extremely likely. I thought it might of had something to do with the backfiring in cylinder 4 or the fact that the temps were getting in the 200s. My fault for thinking it was just the calibration numbers.
Quick Reply: Blown head gasket
