blown head
blown head
ok longgg story,ill try to make it short I had a head rebuild due to bent valves, then honda does the valve adjustment, 3 months later valve drops into pisons and comes out the block i was driveing 50mph in nyc does anyone know what could of happend? dealer said it was the machines shops fault due to loose retainers or valves but can they do a valve adjustment on the motor if that is true? i put 3000miles in the 3 months and never drove it hard pleaseee someone help warrenty doesnt want to pay for it either thankkks
Unless the tech at the honda dealer is a complete idiot, nothing he would have done while adjusting the valves would cause you to drop one. More plausible that it was an err of the machine shop.
The question is, did Honda send the head out to the machine shop or did you? If Honda did it then I think Honda owes you a motor. If you sent the head out then I think you might be screwed. I'd go back to the machine shop. You bent valves from an over-rev right? I wonder if the machine shop replaced the retainers or used the old ones? If they used the old ones, I'd say one of them failed.
i dont see any reason why the dealer sent the head out just to replace a few bent valves, leaving other still in the head. if that was the case, then i ask this; why couldnt the dealer technician replace the valves himself instead of sending it out to a machine shop? was that tech not qualified to replace valves? yet he was allowed to remove the head?
Silver_Bullet_S
10-06-2018 01:15 AM
