blown diff?
blown diff?
I have a very noticeable clunking noise coming from the back of my car. I jacked it up and checked my axles, all fine. then I spun each wheel both directions, when I spun them the other wheel spun in the same direction with no grinding. I did get a small clunk when I started to spin the tire but it only sounded like a little shaft play when I changed directions. I hear the noise mainly off throttle and I hear it most easily when I slowing down to stop. I also hear some whining but that may just be my walbro fuel pump.
I just went outside to try spinning them again. this time for a longer period of time, after a few full rotations the opposite tire stopped spinning for about one rotation and then continued spinning in the same direction.
Originally Posted by Quivers,Mar 20 2006, 12:47 AM
I have honda fluid in it. but it is 1 year old and 27 thousand on it.
Originally Posted by Quivers,Mar 20 2006, 10:05 AM
any onther thoughts???
Im gonna change the fluid today so I guess well see what happens.
Prominent clunking sounds after letting off the gas pedal after moderate acceleration is a good indicator you have rear differential problems, though not absolute. Take it to Honda and hopefully they put the last oil in there and not you.
