block your throttle body coolant
Old 09-03-2006, 06:44 AM
  #121
Hondassport's Avatar
I've always felt that the idle should be artificially high since the IAC doesn't see warm coolant and thinks it needs to keep idle speed elevated.
The IAC is not a sensor,it only does what the ECU tells it to do, the ECU receives data from the all the sensors,ECT,IAT and such and and then tells the IAC what to do, i think they call the IAC a actuator,this is my understanding of it all anyway.....Pete
Old 09-03-2006, 07:38 AM
  #122
Riley2638's Avatar
I will be doing this mod also once I have time to collect the parts...I did this to my boosted civic and ran it for about 4 years with no problems at all..It also gets cold here in North Georgia and I never encountered a problem with stuck idle and such
Old 09-03-2006, 08:06 AM
  #123
xviper's Avatar
Yes, something like that. It has a solenoid in it and this part has been known to malfunction and need replacement. What's weird is, why do they have a coolant circuit running through it if it doesn't seem to care what temp that coolant is? If the ECU uses the coolant temp from the sensor in the back of the engine and the IAT, why put coolant through it?
Old 09-03-2006, 08:53 AM
  #124
IMHO the coolant warms the air that the IAC adds to the IM.......Pete
Old 09-03-2006, 10:19 AM
  #125
Ek9
Banned
Ek9's Avatar
You know, the S2000 IAC is unlike any other honda I'm familiar with. The ECU controls it using variable current. All other honda's (I've looked at) use stepper motors (D16's) and a pulse width modulated solenoid that changes duty cycle to change average airflow (B series engines).
The S2000 one looks like a spring loaded valve that opens a set amount for set amounts of current.
Why they warm the IAC is what we've mentioned before. To prevent icing in wet 30-40 degree conditions.
Old 09-03-2006, 10:41 AM
  #126
Ek9
Banned
Ek9's Avatar
Old 09-03-2006, 02:40 PM
  #127
LUVNMBRS's Avatar
That's interesting...I learned something new today. Guess this sort of confirms it's OK to leave the IAC/TB/IM bypassed throughout the winter, unlike other Honda's.
Old 09-03-2006, 03:43 PM
  #128
Slows2k's Avatar
The S2k's IAC is a rotary valve IAC. It's the same type used on the 3-3.5L V6's. A rotating valve varies the air volume bypassed to adjust for additional engine loads (such as AC, and alternator output) and cold start idle RPM.
Old 09-02-2007, 10:23 PM
  #129
As2kW5's Avatar
Originally Posted by triumph87,Aug 20 2005, 11:26 AM
Where can i find the ball berings??? i went to home depot and they didnt have them
go to a bicycle shop! they have absolutely everything laying around.
Old 09-03-2007, 05:36 AM
  #130
negcamber's Avatar
You just responded to a post made TWO YEARS AGO!
Quick Reply: block your throttle body coolant
