block your throttle body coolant
Old 08-24-2006, 06:41 AM
  #91
Hondassport's Avatar
I installed the balls again this year, makes mine run better on those 102 deg. days...Pete
Old 08-25-2006, 09:43 AM
  #92
falcorider's Avatar
Just out of curiousity, does the coolant going to the TB have anything to do with an EGR (Exhaust Gas Recirculation) system? When I had my mustang, there was an EGR spacer next to the TB which introduced some exhaust gas into the intake stream, the purpose being to reduce NOx. The EGR spacer had a coolant jacket to help reduce the temperature of the EGR spacer.
Old 08-25-2006, 01:43 PM
  #93
xviper's Avatar
We don't have an EGR system.
Old 08-25-2006, 05:20 PM
  #94
rehile's Avatar
Originally Posted by ghoonk,Jun 21 2006, 03:14 PM
I'm in Dubai now, and temps are all the way up to 42 deg Cel, humidity is through the roof. I'm try this mod out and keep everyone posted on how well this works here once I get my hands on some 3/8" ball bearings at Ace Hardware
"that's hot"
Keep us posted, ghoonk.
Old 08-31-2006, 11:49 AM
  #95
B.Piper's Avatar
Guys,
I have had this mod for a while now.
I do a lot of short runs in the S.
Since I live only about 3-4 miles away from work
Since I did this mod i havent noticed any improvement
in performance but i have noticed a slight increase
in MPG.
I think this might be because the inlet manifold is still
just warm when i get to work. Where as before it was
hot in seconds...
Barry.
Old 08-31-2006, 12:28 PM
  #96
OvErMiNd's Avatar
What if you have a hondata IMG? Will it cool things down any?
Old 08-31-2006, 12:32 PM
  #97
Ek9
Banned
Ek9's Avatar
Unless you mod the gasket. The Hondata disables the manifold heaters permanently.
Old 09-01-2006, 04:26 AM
  #98
rikhemi's Avatar
Just a quick question..Im here in south florida and experience the heat bog quite frequently. For our winter days, which the temp in the coldest days gets in the mid 50's to 60's, should I take off the balls.
Thank you
Old 09-01-2006, 06:54 AM
  #99
Incubus's Avatar
Thank you
You may want to remove your balls. Much like a cat in the winter, you will have undesirable performance...unless you remove the balls.
Old 09-01-2006, 11:00 AM
  #100
8BALL's Avatar
Quick Reply: block your throttle body coolant
