Blew my driveshaft
#21
The lock nut on the output shaft is torqued to 119ft lbs, backed off to 0 ft lbs, then re-tightened to 119ft lbs. I think the driveshaft bolts will back out at the factory torque specs, and that is why they come with thread locker from the factory.
#27
Mine did, although it might have been bolt corrosion, there was a white residue we thought it was a thread lock. Haven't seen it on other cars I've done, but to be honest the clutches I've done, were basically swapping out a cheap replacement clutch for the real deal. Anyway I always place a tiny dab in the middle of the threads, it won't make it any harder to remove than an old untouched bolt. I came to this conclusion after I swapped my prop shaft 3 months after I did my clutch. It's probably overkill, but I'm not planning on touching my transmission other than for fluid changes.
