Blew my driveshaft
Originally Posted by Andersonracing' timestamp='1358480062' post='22274684
Wow, you really lucked out. usually when that happens the drive shaft goes thrashing through the undercarrage tearing apart the tail housing of the trans and any wiring in its way!
Notice that it broke on the transmission side of things, so it would not thrash around too much before he had a chance to react to the noise.
My diagnosis is improperly torqued bolts. one of them was likely cross-threaded a bit and that caused a moderate rotational interia to develop into more and more movement. eventually, spinning that fast things go snap.
Strange for an S2000, but common with GM muscle cars, that why they require a drive shaft loop for cars on the track.
Originally Posted by ipopvtec' timestamp='1358470801' post='22274423
What could have happened? Looks like it disconnected/broke/snapped. Hopefully no bolts broke in the transmission side. Last time the shaft was off was when I did my clutch (March). Since then I drove almost 7,000 miles... HARD. NJ to North Carolina tore up the dragon for a weekend (April) and it broke in November... Never felt a problem till then. I make 200hp to the wheels.
I am thankful for the loop. See my replies above
Member
Can't go after anyone for damages then. Thankfully the parts you are looking for is not that expensive. New companion flange (with accompanying nuts, bolts, and ext) on the transmission side and a new drive shaft. You're good to go. Very lucky it wasn't on the diff side.
[/quote]
bought a new flange just to be safe
the bolt torque spec is 24 ft lbs, so they don't use very much torque
