Blew my driveshaft
Blew my driveshaft
Blew my driveshaft. Was driving in traffic and heard a light clicking sound at random. Sounded like something was stuck underneath. I go on a few more miles... traffic. Thought I would make it to my destination and check it out. Then as I start speeding up 40 mph, the clicking gets BAD in neutral. Then I hear a huge CLUNK. Next stop light I hear a bolt fall and car acted if it was in neutral in gear. Got the car towed home and saw the driveshaft hanging down.
What could have happened? Looks like it disconnected/broke/snapped. Hopefully no bolts broke in the transmission side. Last time the shaft was off was when I did my clutch (March). Since then I drove almost 7,000 miles... HARD. NJ to North Carolina tore up the dragon for a weekend (April) and it broke in November... Never felt a problem till then. I make 200hp to the wheels.
Since then I found an aluminum one with u-joints that a member was selling from the driveshaft shop and is out getting balanced at a local driveline service. Just wondering what I can do to prevent this again (new bolts torque etc.) and what actually happened.
umm maybe u popped a stronger VTEC this time...
but yea sorry for your incident. maybe the bolts werent tight enough or somehow the drivetrain slack must have gone away. that slack is there to prevent a problem like this happening.
My diagnosis is improperly torqued bolts. one of them was likely cross-threaded a bit and that caused a moderate rotational interia to develop into more and more movement. eventually, spinning that fast things go snap.
Strange for an S2000, but common with GM muscle cars, that why they require a drive shaft loop for cars on the track.
1 Post
Originally Posted by Andersonracing' timestamp='1358480062' post='22274684
Wow, you really lucked out. usually when that happens the drive shaft goes thrashing through the undercarrage tearing apart the tail housing of the trans and any wiring in its way!
In my opinion/experience, insufficient torque could cause the bolts to fail because it allows for cyclic loading of the bolts themselves instead of the bolted joint.
