Bleeding the clutch. What fluid to use?
Im going to change my clutch fluid soon, and I was just wondering what fluid everyone is using in theirs.
I know it has to be dot3 or dot4 brake fluid, but im wondering if any brand is better than the next.
What would you guys recamend? I figured I would go to Pep Boys and see if Mobil 1 made any, if not check HTG.com out.
Originally Posted by Cherry04,Sep 30 2006, 02:46 AM
Could be wrong on this but doesnt the owners manual say only use Honda clutch fluid only?
I mean they're prob tryin to make some $ but theres nothing like OEM
sometimes.
sometimes.
You can use any DOT rated brake fluid as long as it's the same rating as OEM. I can't remember if it's 3 or 4. Just check the OEM grade from your owners manual in the back and then you can subsititute.
No real need to though. Just go to the dealer and buy a bottle of the OEM grade brake fluid for $5 and do the bleed yourself.
That's what I do.
Tim
That's what I do.
Tim
You can use any DOT3 (or DOT4) brake fluid. But the Honda fluid is as good as any and fairly cheap. I run high temp fluid in my brakes because they get hot out on the track, but I run the Honda brake fluid in the clutch because there is no reason not to.
Originally Posted by Ek9,Sep 30 2006, 08:19 AM
The good brake fluid tends to absorb water faster than dot 3 too. For the clutch I'd use DOT3.
I haven't seen mobil 1 brake fluid, but you don't need it. ANY DOT3 fluid is more than up to the task.
Valvoline makes a good DOT3
