bleeding clutch
bleeding clutch
I need to change clutch fluid and I remember saw someone posted we don't need to bleed the clutch. Just empty the clutch fluid, clean the inside and refill the DOT 3 brake fluid. Is that correct? Or I better bleed the clutch?
If you clean it out you should go ahead and bleed the clutch. Here is a good write up on it.
http://forums.s2kca.com/showthread.php?t=12154
mlc
mlc
