Bleeding brake system
Originally Posted by NFRS2kSi,Nov 30 2005, 07:18 PM
if you can bleed clutch then u can bleed brake... same procedure.
On the S, yes.
Although some cars w/ ABS have special bleeding procedures.
Originally Posted by GrimReaper,Dec 1 2005, 10:08 AM
1. The process from the point you mention usually takes me about 20min. (I also use a vacuum bleeder)
What kind of vacuum bleeder do you use? Can you do this alone (no helper?)
TIA
Daniel
Originally Posted by dangarza,Dec 1 2005, 11:52 AM
Thanks Sam.
TIA
Daniel
TIA
Daniel
