Black Residue in Throttle-Body / Intake. Pics Inside
Was cleaning out my engine bay this past weekend. I took the intake off (FIPK) and saw that there's this black soot-like residue (oil?) all around the butterfly valve. Any idea where this is from? Is it bad?
More info: Car is a MY'00, 40k miles, oil changed every 4k religiously, only mods are FIPK, headers, catback & 70mm HFC. Never had any other engine work done but runs perfect.
That is very normal, it is just oil vapours from the pcv system and valvecover vent. Airflow form the pcv valved and valvecover vent will introduce oil vapours to that part. I try to clean up the TB plate whenever I have the intake arm apart, but at the end of the day it probably doesn't mean anything in terms of airflow and performance, it just looks dirty.
What Jfusion said. Just clean it out, and clean the FIPK tube too.. try to make it all the way back to the inlet from the 1/2" vent hose between the FIPK and valve cover.
Former Sponsor
Yup very normal. If you want to prevent that you need to get a vented catch can and then cap off the nipples on the intake manifold from the valve cover. No oil would be able to get into the intake manifold then.
I had a puddle of oil in mine when I checked from being boosted and still having the lines coming from the valve cover to it.
AP2s still vent the valve cover directly into the pcv/intake system, but they don't seem to suck out oil like AP1s. This is a main contributor to oil loss in AP1s, and why the intake/throttle body get dirty.
