Bilstein PSS9 Install Help Needed
I'm in the middle of installing a set of Bilstein PSS9 coilovers and am having trouble assembling the new shock. I removed the stock spring hats and drilled out the hole so the shaft and shaft spacer would fit through, but I still don't have enough shaft sticking out of the top of the hat to add the rubber piece and adjuster unit. What am I missing? Thanks in advance.
Rob Robinette
Rob Robinette
It looks like the stock hat has a metal and rubber "cap" that needs to come off to make everything fit. I have tried to pry it off but it seems to be attached pretty solidly.
Any help would be appreciated.
Rob
I don''t see your pictures.
Also, when I installed mine, I don't remember drilling anything. I also don't remember it being that hard either. If I could see the pictures, maybe I could help?
Can you take them apart and show me the order of the parts you have them installed? I.E Shock, Bushing, Top Hat, Bushing etc....
I think you have one of the stock bushing still installed on the bottom of the tophat.
No, that does not need to come off.
Rob
