Big Problem! Help!
#23
Best way to destroy a car
I'm almost certain you will find an issue with the stereo and speaker install.
-currect fault: high current due to short circuit, fuse cannot blow, so the harness melts
-underlying fault: likely shorted component in the stereo install.
If they replace the harness (which is the entire dashboard and ECU harness BTW) the underlying fault will still be present and must be corrected.
#25
Originally Posted by Kengthao91' timestamp='1333577118' post='21576655
i put a 30a in it since i didn't have anymore 10a...
S2000_Steve
01-28-2010 02:01 PM
