Big Problem! Help!
Big Problem! Help!
help!! this morning the car is running normal but when i came out of work, drove the car and then smoke start coming out under my steering wheel, front and rear air vents, and behind where the cig lighter is located, I then park, put down the top and check the engine, check all my fuses and they were good, then my stereo and cig lighter die, door light is on when all the door is close, right of the soft top stop working but the left still works, and the lock button on the remote is not working.. anybody have any suggestion? if not then i probably take it to honda, and yeah this have never happened before
I think he is referring to disconnecting the battery so that if there is an electrical short of some kind, your car won't go up in flames/the short won't cause more damage than it already has. Has anything electronic been installed recently? It is rare for our wiring to spontaneously go bad without some outside help, our cars aren't quite old enough for the stock insulation to be rotting away, so there's a good possibility that there is a mechanical cause to this. If you don't have someone local to take a look at it for you, bring it to a shop. (on a tow truck of course)
Originally Posted by Fasting' timestamp='1333541491' post='21574288
Disconnect your battery.
Call a flatbed.
Call a flatbed.
Originally Posted by Kengthao91' timestamp='1333570672' post='21576255
[quote name='Fasting' timestamp='1333541491' post='21574288']
Call a flatbed.
Call a flatbed.
[/quote]
ok thanks i will try that
