BIG Problem!
#21
Originally Posted by BushidoS2K,Sep 27 2006, 08:14 PM
small update i went to my local shop and got the CEL code its P1253
P1253 VTEC System Malfunction
The manual does suggest that the very first thing to do now that you know the code, is to reset the ECU and see if the problem persists. The next thing it says is to check the oil level. I would suggest that you check it again and check those 2 wiring harnesses. Reset ECU by pulling the "BACK UP" fuse under the dash for 1/2 a minute and put it back in (with ignition OFF). After that, it gets quite lengthy and you should take it to the shop if it's not resolved with these first 2 things. Something more serious has resulted.
#22
ok well i checked out those things and everything seems to be OK, and reset the ECU. Pretty much i still have that noise, but now the check engine light is not on. /shrug
Forgot to mention, now it seems like it wants to stall after its been revved up, it'll dip to like 1k rpm then come back up.
#23
#25
Originally Posted by BushidoS2K,Sep 27 2006, 07:51 PM
i never had it before, its pretty gawd aweful and very loud. Its something that u cannot miss.
#27
I still recommend a double check of the oil level. It's not always the easiest thing to read properly. Make sure you're not just seeing oil splash on the stick.
#30
Originally Posted by xviper,Sep 27 2006, 07:03 PM
Under certain conditions, revving the engine with the car just sitting there will cause this even in a perfectly normal car. It's not necessarily an indication of anything to do with your situation. Just don't rev it like that. You probably don't want to be revving it when something could be seriously wrong.
