which is better?
which is better?
turbo or supercharger? i went through the search part but i couldnt find anything, and the link i tried didnt work..so any input would be nice..also, if this has been asked a lot, well, answer some more?
thanks.
"D"
thanks.
"D"
there isnt really a "better" boost. I prefer a turbo because so far they have potential to make more power. They also will hit full boost at a certain rpm, as where a centrifical blower will reach peak boost at almost redline.
Neither is better... you need to get a displacement transducer matrix and enough capacitors to supply it with 1.21 gigawatts of power for a nominal time. The amount of time the inrush current will require will vary depending on the amount of torque you will need calculated as an inverse proportion the the amount of kimchee I'm expelling.
-BS2KT
-BS2KT
[QUOTE]Originally posted by BlackS2000Turbo
[B]Neither is better... you need to get a displacement transducer matrix and enough capacitors to supply it with 1.21 gigawatts of power for a nominal time.
robertm
05-24-2014 11:09 AM
