Best oil to Run?
#51
I always get a chuckle out of oil posts where people say 'I use X and haven't had any problems'. What sort of problems do you think you'd have? The S2000 is probably harder on oil than most any other car around, and even if you use the worst oil you can find (of the correct grade), its not like your engine is going to blow up. You'll just get less life out of it than you could have with better oil. So you wouldn't know if you had any problems until you've got the kind of miles where an S2K motor would be used up, and if your motor died near that many miles, how would you know if your choice of oil shortened its life? Its not like you know exactly how many miles you should have gotten.
Now if someone posted their oil analysis results to show how their oil choice was doing, that would be worth hearing about.
#52
#54
Originally Posted by accord31' timestamp='1352822478' post='22147872
There is really no reason to use ultra expensive synthetic oil in any engine unless you want to extend the oil change interval to 10,000 miles or over. Most if not all oils on the market are made to far exceed manufacturer's requirements. Good quality inexpensive paraffinic based oils would be my choice. Examples Quaker State, Pennzoil, Kendall. As long as they use Pennsylvania Grade oil stock they won't break down at high revs. Stop wasting your money with synthetics. Take it from a lubrication engineer. We had 12,000 HP centrifugal compressors running 24 hours a day for two years straight at 10,000 RPM with gears reducers running on 30 weight straight grade paraffinic base nineral oil without any problems.
2. I guess I just love sarcasm and humor all bundled up in truth, ha!
#55
1. Oh, I just realized I hadn't added my 2 cents.
2. Used Mobil 1 from 9k miles to 40k miles, w/o any oil consumption, and just switched to Amsoil, which I have been running in the tranny and diff. as well.
3. Why? Because when I was a teenager back in the late 60s, it was supposed to be the hottest fluid around, and I have waited for a car worthy enough, and my income solid enough, to fulfill yet another lifelong goal.
4. Yes, the S in the top of my car goal list!
#56
#57
Originally Posted by kerm1t' timestamp='1352269172' post='22134712
mobile = burns most oil
amsoil = burns a little less
castrol edge = burns zero.
out of all them the castrol burn the least amount of oil plus much lighter on the wallet
yea i was skeptic to try castrol, but thats the only thing i use now. i think the price is the same as mobile 1
#59
Originally Posted by S2KiChad' timestamp='1353826024' post='22169856
[quote name='kerm1t' timestamp='1352269172' post='22134712']
[/quote]
1. I pay $6.50 for Mobil, and $8 for Amsoil, and since I will only change oil 1x/yr since it is 25k oil, and I only put on 12k in a year. I use the Amsoil filter since I figure it should be built for the higher mileage.
#60
1. Question: If I am going to change Amsoil once per yr. would you advise doing it before or after winter for the 1x?
2. I presently am on schedule to do it now (Thanksgiving) every year, but I could change that to the spring or in the summer is it makes a difference in anyone's mind, ha!
